주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 또는 2.8 GHz quad-core Intel Core i5. 2015년 10월 13일 출시.
What does blinking LEDs 1 and 2 mean?
iMac 21.5” does not power up, no chime is heard. I know that LED codes are: LED 1 on= trickle voltage from power supply is detected by logicboard. LED2 on= logic board has detected proper power from the power supply when the computer is turned on.
The problem is BOTH LEDs 1 and 2 are BLINKING (not ON continuously) when I connect the AC power cable to the mains wall socket. What problem does this point to?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개:
Can you offer some additional details on what preceded things here.
의
Nothing unusual happened prior to. Thing just suddenly won't turn on.
의
Where is the light coming from?
의
Light comes from the vertically arranged LED array on the logicboard.
의
댓글 달기
답변 1개
What does the other LED’s telling you?
이미지
Did you try reseating the RAM? Did you replace the RAM you might have a bad SO-DIMM.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
The RAM is permanently soldered to the logicboard in this model, and cannot be replaced.
의
Dan, when I press the power button, the 2 other LEDs remain unlit, #1 and #2 LEDs turn off. When I release the power button, LEDs #3 and 4 remain off and #1 and #2 start to blink again.
의
@Bernie - Sorry your right! One of the few iMacs with soldered RAM.
I think your logic board is blown then.
의
댓글 달기
답변을 추가하세요
Bernie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 14
전체 시간: 529
