주요 콘텐츠로 건너뛰기
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
Why does my iPod nano lose battery so quick?
I charge my nano until it's fully charged but it runs out of battery about 2 hours later.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 4개
My 4 gen ipod mini dies so fast when it's fully charge as I remove of the charger to go low battery what should I do?
I got a 6th gen nano and when its fully charged I will unplug it, but it literally dies in 5 seconds.
I have this problem as well ... it's a new Ipod Nano, I charge it fully, I play it, and it dies in less than 2 hours.
you need to replace your battery. it does require soldering.
댓글 달기
답변 2개
가장 유용한 답변
It does sound like your battery is ready to be replaced. Follow this guide to show you how to get to the battery. It is a bit of a PITA due to the size of the Nano. Of course, before you take it apart, you could also give this a try. the battery is available at places like this. I hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
thanks 4 the info but the thing is i just got it about a week ago. Could it b something else?
Not really, you could check on your settings and make sure that your EQ is off etc. You might also try another charger, anything is possible. If you just recently got it, any chance you got some sort of warranty?
thanks sooo much
댓글 달기
Maybe Its cause since it is so tiny that the battery should be tiny to so that means a little bit of battery
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Vicki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 8,408
