주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Game Boy Advance의 업그레이드 버전인 Advance SP는 2004년 3월 23일 북미에서 정사각형 구조와 클램셸 디자인으로 출시되었습니다.
Power turns on then off
When I turn my game boy on, the power comes on for a second and then shuts off. When I plug the charger cord in the green light comes on for a second and then shuts off.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
i had the same inssue but the power light only brinks and it not turn on at all my batery and charger are good , i measured all i know do but not found if had a shortening or power for the cpu please help
의
I dropped mine while it was closed and it hit the concrete, when I tried turning it on again it didn't work even charging doesn't work.
의
@carsonhovis time to open it up and to check for physical damage.
의
Meu primo quebrou o carregador e tentou fazer uma cambiarra direto no conector interno da bateria com os fios, porem eles se tocaram e não deu sinal, foi comprado um carregador novo porem a luz acende e apaga e ele dá um breve sinal de que funciona e apaga
의
댓글 달기
답변 4개
선택된 해법
Had this same problem with 3 SP’s I picked up. It’s not likely a big issue at all so don’t worry. It means you need a new battery. Luckily nintendo made it really easy. All you need to do is buy a replacement, you can get cheap ones from amazon that’ll do the trick. Though before you buy the new battery, check the back of your console, you’ll see the battery compartment held in with a phillips screw. It’s better if you can open it and take the old battery out to check, but even if you can’t at least check for any bumps/ a bulge in the plastic. If there is a slight bulge in the plastic around the battery compartment, this means the battery is starting to expand, and it can damage your gameboy if left unchecked. Best of luck! (by the way most batteries for it come with a little screwdriver so don’t worry if you don’t have the right size)
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thank you for the advice! Ordered a battery. Just waiting..
의
New battery didn’t work. It still shuts off immediately.
의
@nardbarber If the battery replacement didn't work then maybe it could be a problem with the power switch, which is a lot more difficult to fix than a battery replacement but shouldn't be too bad. If that is the problem, you might not even need to replace it, could just need a bit of a clean.
의
댓글 달기
The most common cause is the F1 or F2 fuse.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i find its more often bad contacts. no reason not to check fuses first. this happens a lot on later models when the screen ribbon is loose or dirty. it is very common for gba-sp to have a dirty screen ribbon or port. electrosolve contact cleaner works for me most of the time. the almost equal culprit is the power switch itself. the copper contact requires cleaning. electrosolve usually does the trick but realistically or just as often removing the shielding and wiping (careful not to bend) the copper contacts with eraser is required. (or replacement.)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dustin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 144
전체 시간: 9,163
