주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년에 출시된 Flip Mino HD는 4GB의 저장 용량과 1시간 촬영이 가능한 휴대용 캠코더입니다.
Replacement for Flip out USB
Hi there, my Flip Mino HD has a damaged ribbon cable for the USB on the camcorder, I can no longer charge it without the usb. If I can fix the ribbon cable how would I do that, If I need to buy the part where can I buy it from? All help would be appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You need to find out how many wires are in it than order a roll of flat ribbon cable from Amazon.
https://www.amazon.com/s?k=flat+ribbon+c...
이 답변이 도움이 되었나요?
점수 1
댓글 9개:
I can’t find the right one and the cable is physically attached to the flip out usb of the camcorder.
의 공유
@TechVid How many wires is in the ribbon?
의 공유
Alao a picture of that connection will help but it's probably just soldered. The wire can be split apart and soldered into place.
의 공유
It is a flat flex cable and I am not sure how to do micro soldering nor do I own a soldering iron
의 공유
Is it true that I can cut the rest of the cable, scratch a little bit of the torn side of the cable until the connectors are showing on both sides of the torn cable and tape them together with both sides touching? Also thanks for not telling me to get a new camcorder, the camcorder is special to me.
의 공유
댓글 4개 더보기
댓글 달기
답변을 추가하세요
TechVid 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 16
전체 시간: 500
