Not able to scan to file
Printer is connected to the wireless network and all devices - laptops, phones and tablets - can send files to the printer which are successfully printed, i.e. the MFC is connected to the network. However, when I try to scan from the MFC to laptop the error message “Not able to scan to file” appears on the MFC screen. When I go to the control panel the MFC scanner profile says it is working correctly. I do have a work around (scan to USB drive then transfer drive to laptop) however this is not ideal. Any solutions would be appreciated. Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
Are you scanning to the laptop via the printer's built-in software or via Windows?
Hi Andrew, I'm not sure, I have tried both the WSD port (is that windows?) and the two Standard TCP/IP ports that begin with BR on the assumption that the BR relates to Brother. The printer function is working using the WSD port. Regards, Ian
@Ian Shields Does the laptop run Windows?
Yes, Windows 10
댓글 달기
