주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
XP-410은 최신 무선 표준과 Wi-Fi Direct1을 지원합니다. 또한 Apple® AirPrint™ 및 Google Cloud Print™를 지원합니다. 내장 메모리 카드 슬롯, 2.5인치 LCD, 편리한 터치 패널 덕분에 PC 없이도 테두리 없는 맞춤형 사진을 다양한 레이아웃으로 인쇄할 수 있습니다.
How can I fix error code 0x9A
I have an Epson XP-610 that was in storage for 2-3 years. I pulled it out to see if it still works, to give to my uncle. Everything worked but it wouldn’t print - every sheet came out blank. After researching why it wasn’t printing, I determined the printer block was clogged with dried ink. Researched that and followed the procedure to put paper towel under the printer head and force water through the ink ports. Too cumbersome and time consuming. Followed instructions on how to remove the printhead and soak it in warm water to remove the ink. Took about 45 minutes to get clear water. Reinstalled the print head and when I turn on the power it says “Internal problem. Turn the power off. Error code 0x9A. Followed Epson website recommendations but nothing works. Followed suggestions made on internet. Still nothing works.
Is there any way to determine what might be causing the error? I’m pretty sure I got the wire cable back the way it’s supposed to be. Don’t know where else to look. I’m not going to take it in because it’s not worth the cost to have someone fix it. I’d like to take it on because I have nothing else to do and like the challenge.
Any suggestions appreciated.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Disregard. I purchased a new printer.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Disregard. Purchased new printer
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jack Anderson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 34
전체 시간: 1,305
