주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 11월에 출시된 Orbic의 스마트폰입니다.
I can't see USB attachment
My orbic cell phone doesn't see the attached device using the USB
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @jonnaland,
Are you trying to connect a USB 2.0 device to the phone?
Assuming that you have an Orbic Wonder as selected, you need to connect the USB device via a USB-C to USB 2.0 OTG cable adapter (supplier example only).
OTG (On The Go) adapters are required to signal the phone that it needs to supply power to the hosted USB 2.0 device so that it can function.
If the USB device is also USB-C then it should not need an adapter as there should be signalling between the 2 devices when they first connect, that ensures that the phone will supply power to the hosted device.
Here’s a link that shows how to check if the phone supports OTG. Most modern Android phones do.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jonna land 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 557
