주요 콘텐츠로 건너뛰기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86, 또는 2.13 GHz Core 2 Duo 프로세서
312 질문 전체 보기
repair logic board soldering audio connector
Hi. I was replacing the audio cable on my mba (sound is out). I was on the last step of disconnecting the audio cable connector from the logic board. Then, as I gently pried it up with the spudger, the piece from the logic board that connects the audio cable was still inside. So, can I repair this piece by soldering it back onto the logic board? Please say "Yes!". I know the prongs holding the piece onto the logic board are on the piece and some on the board.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
What have you got to lose? But it's a simple job and would probably only cost $5-$10 if done by an expert. Want to risk your motherboard?
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Easier to solder the audio wires directly to the motherboard (cutting off the connector and stripping the wires end) once you have found out the good contact locations (left right). Find a technician who will do it for you. Cheap repair...
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
cu20four7 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 2,691
