Please turn camera off and on again
Hii there,
My Lumix TZ60 also display these error messages (System Error (O.I.S) and Please turn camera off and on again)
If you guys solved the problem please help me. Thanks ya
좋은 질문입니까?
Hii there,
좋은 질문입니까?
@zaix most common issue with this “Please turn camera off and on again” is a stuck lens. Once your camera turns on it tries to extend the lens, if it is stuck you get the error message. Check on here for a possible solution
이 답변이 도움이 되었나요?
This solution did not work for my camera. I think I will send it to the service center ASAP. Thank you for your help ya.
@zaix sorry to hear this. Check the prices for a replacement lens and see if you are up for replacing it yourself, if it is not to expensive.
I also had this issue and found another fix. Seems to be the cable ribbon connecting the zoom button to the camera.
I wrote a guide here:
Panasonic Camcorder 'Error Occurred. Please turn unit off , then on again - iFixit Repair Guide
이 답변이 도움이 되었나요?
By any chance do you still have this guide?
Please can you share a link to the guide.Thanks
지난 24시간: 6
지난 7일: 91
지난 30일: 350
전체 시간: 17,985
댓글 2개
I would start by removing the battery and turning the camera on/off a few times, then reinstall a fresh battery to see what happens.
bill 의
@ruggb This solution did not work for my camera. I think I will send it to the service center ASAP. Thank you for your reply ya.
Zaix 의
