주요 콘텐츠로 건너뛰기
Drum set accessory to the Wii game, The Beatles Rock Band, which was released in 2009 by Harmonix. This repair guide will give you help on fixing and/or replacing certain parts of the drum set. Identified by model number NWDMS3.
2 질문 전체 보기
Will not power on
Recently got out of storage. There was some corrosion on the battery contacts, when cleaned off all connections were checked and there appears to be no damage inside the wire casing. Tried several different batteries. Looking for suggestions, or if it is a lost cause.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You could put a multimeter in DC voltage mode and check to see if battery voltage was making it to the actual circuit board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jared P Neslen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 130
