주요 콘텐츠로 건너뛰기
How to troubleshoot a gray screen on start up.
I have a Apple A1010 laptop that when you turn it on, it chimes and goes to grey screen and doesn't do anything. It is not the hard drive or the memory because I tested them in another laptop.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
I did that but the ram is good this laptop has 128MB of built in RAM thats not removable. could that be the problem
When you tested your hard drive in another computer, were you able to boot off of it? If so, you might want to make sure everything is connected properly inside you laptop.
yes it booted up fine and the conections are tight.
댓글 달기
답변 2개
선택된 해법
I guess you tried all usual troubleshooting stuff like reset the pram, reset the PMU, boot from external source, boot in single user mode, fsck scan, connect the PB to an external monitor, etc ?
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Test the RAM in another laptop, could just be bad RAM.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 2,617
