주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년형 Retina MacBook의 업데이트 모델. 모델 A1534, EMC 3099. 최대 1.4 GHz Core i7(최대 3.6 GHz Turbo Boost)의 더 빠른 Kaby Lake 프로세서와 최대 50% 더 빠른 SSD를 탑재했으며, 최대 두 배의 메모리를 지원합니다.
Display error - lines on right side
Hey guys,
I plan on buying a used MacBook 2017 Retina. The picture shows, that it has a display error on the right hand side. As I will mainly use it with external displays attached, I don’t worry too much about it, but would like to know, if this is a common problem that is easily fixable or a bigger problem that needs a fix from apple?
Thank you all for your help,
Stefan
Hallo Leute,
ich habe vor mir ein gebrauchtes MacBook 2017 Retina zu kaufen. Auf den Bildern sieht man, dass es einen Displayfehler auf der rechten Seite hat. Da ich es hauptsächlich über externe Monitore betreiben werde, stört mich das nicht allzu sehr, aber ich würde gerne wissen, ob dies ein bekanntes, leicht zu behebendes Problem ist, oder aber etwas schwerwiegendes, was eine Reparatur von Apple benötigt.
Danke für eure Hilfe,
Stefan
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
The LCD panel in the lid got damaged. Likely along the edge so som e of the lines got severed. Sadly this will require a new display assembly MacBook 12" Retina (Early 2015-2017) Display Assembly iFixit only has the Rose Gold in stock. Here’s the guide to put it in Retina MacBook 2017 디스플레이 어셈블리 교체
Here’s a run down on the Apple P/N’s for the different units:
  • Gold - 661-02248
  • Space Grey - 661-02266
  • Rose Gold - 661-04852
  • Silver - 661-06786
Replace a display compatible with the early 2015 to 2017 model A1534 12" Retina MacBook laptop. Includes the 2304 x 1440 pixel 12" LCD screen, aluminum case, 480p Facetime webcam camera. 이미지
제품
$584.99
이 답변이 도움이 되었나요?
점수 1
댓글 7개:
Sadly there are no replacements available for Germany. Any idea where I can source one that ships to Germany?
의 공유
@narunac Which one? Silver, Space Grey, Gold or Rose Gold?
의 공유
Sorry. Rose gold.
의 공유
@narunac - Sorry it appears they are hard to come by right now. Give these folks a call TheBookYard Reference the part number.
의 공유
true, i would recommend finding a donor laptop of the same kind MAKE SURE THE SELLER SAYS THE SCREEN WORKS, then transfer it to the laptop
의 공유
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Stefan Teucher 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 469
