주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore 90 Series는 Kenmore에서 제조한 가정용 세탁기입니다.
Will do everything but spin
So my machine will do everything all around the dial except any of the three spin cycles. Thanks for any time you choose to give me :)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
having same issue but when the machine gets to spin cycle it is not draining or timing to rinse cycle it just stops. I do not hear the motor working and the agitator is doing nothing just sits there on the spin cycle with water still in. please help me trouble shoot so I can fix it
My washer spun once then stopped in spin cycle now it just has a loud wine noise and won't spin. What can I check.
댓글 달기
답변 2개
선택된 해법
You have not given much information to go on to narrow it down to any specific system or part. From what you have given us, here are some things that could cause the problem:
1.)Timer - If it isn't telling the motor to turn in the proper direction and speed or briefly pause after the pump out, this washer will not spin.
2.) Lid Switch - This is a safety device. During spin cycles it is put in series between the timer and the motor to prevent user harm. It allows the motor to get electricity when the lid is down and takes it away when the lid is up.
3.) Out of Balance Switch - A safety device. During spin cycles it is put in series between the timer and the motor to prevent harm to the machine. It allows the motor to get electricity when the basket assembly is in the proper plane and takes it away when the basket assembly is off kilter. Not found on all models of this series, only the more expensive models.
4.) Spin Clutch Assembly - This is the interface between the spin tube and transmission that causes the spin tube to spin.
5) Drive Block - This is what attaches the basket to the spin tube.
6.) Centrifugal Switch on the Motor - This is the interface between the wiring harness and the motor. It tells the motor which set of windings to use.
7.) Motor - This has a multi-speed 2 direction motor that incorporates multiple windings to achieve some of it's functions.
8.) Wiring Harness - If there is an unintentional break between the timer and the motor.
Please tell us more about what this washer is doing or not doing.
Is it pumping out water? Is the motor running at all during spin? Is the motor running but the basket is not turning? Have you visually seen the agitator working?
이 답변이 도움이 되었나요?
점수 6
댓글 1개:
wash and rinse,but not spine.The motor is working.
댓글 달기
yup! same darn thing as mine, $5 lid switch on E-Bay.
No I didn't believe it either. Go to YouTube and find
how to change the switch. In that video the guy has the switch
bypassed so it will work. Try that and you will say I
can't believe it is the switch!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Steve 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 4,675
