์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
์ˆ˜๋ฆฌ ์ปค๋ฎค๋‹ˆํ‹ฐ ๊ฐ€์ž… - ๊ณ„์ • ๋งŒ๋“ค๊ธฐ
2020๋…„ 5์›” ์ถœ์‹œ, ๋ชจ๋ธ ๋ฒˆํ˜ธ 81MW๋กœ ์‹๋ณ„
Computer stuck at moving cursor
My computer is on but blank I can only see a moving cursor
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
With limited information, what we can do to help is limited. What you can do to quickly check if itโ€™s an SSD failure, check if the hard drive shows up in the BIOS โ€” oftentimes, failed drives do not show properly in the BIOS under the boot options, or instead of showing as something like โ€œSamsung PM951 256GBโ€, it shows as if a cat was on the keyboard.
If the drive shows up correctly, check the SMART status to make sure itโ€™s okay with something like Parted Magic (paid by author, but GNU Public license means redistribution is legal so other sites host it). The issue with free downloads is itโ€™s โ€œas-isโ€. If you see it passes, then what you can do is read the drive and make sure the structure isnโ€™t off, which may indicate OS corruption. If you do not want to pay for it, look up โ€œparted magic downloadโ€ and make sure the site isnโ€™t too shady. This is a little older than the current version, but itโ€™s not from a shady site.
If the drive doesnโ€™t look corrupted, you may be able to fix it by reloading the MBR with a Windows 10 boot drive using bootrec.exe \fixmbr. It doesnโ€™t always work, but itโ€™s your best realistic chance to dodge a Windows reinstall.
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Nozipho ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 0
์ง€๋‚œ 7์ผ: 4
์ง€๋‚œ 30์ผ: 11
์ „์ฒด ์‹œ๊ฐ„: 212
