주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Watch Active는 대한민국 전자 기업인 Samsung Electronics에서 설계, 개발 및 생산한 스마트워치입니다. 모델 번호 SM-R500으로 식별할 수 있으며, 2019년 3월에 출시되었습니다.
Display keeps opening up
The display on my Samsung Galaxy watch won’t stay down. Is there a way to glue it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 9개
Hi @ltbob9, can you update your post to share which Galaxy Watch you have?
의 공유
의 공유
When you say the display is not staying down, do you mean the back plate is popping off? Is it screwed on properly?
It would be really helpful with trying to troubleshoot your issue if you could share a photo of where the watch is coming apart.
의 공유
After a short flight my front screen has lifted up and my watch is not displaying.
I can see a small amount of glue but it no longer appears to want to hold the glass plate in place. I have not put my watch into any water or extreme heat. It is immaculate in condition.
I have a Samsung Galaxy Active Watch that is just over 2 years old.
의 공유
You'll need to open it, clean out all the adhesive, and replace with an adhesive that fits that particular shape and size.
의 공유
댓글 4개 더보기
댓글 달기
답변 2개
가장 유용한 답변
Hi Robert,
when I did the guides for the Galaxy Watch Active I could not get the display off of the frame. It seems to be glued down solid in my case.
If your display is coming off you probably need to disassemble it (see this guide here) and then apply new adhesive. Easiest would be using a replacement adhesive (unfortunately we don’t have that in our store yet, so just google for it).
(It also might be feasible with this glue, but be careful when applying it so nothing spills on components on the inside.)
Make sure to clean the glued areas before applying new adhesive (use isopropyl alcohol >90% and a spudger and maybe a lint free cloth).
Good luck with the repair, keep it up
A clear industrial strength adhesive. Bonds metal, wood, fabric, glass, ceramic, and other surfaces. 이미지
제품
E6000 Adhesive Glue
$2.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Can I get my face on my watch to stay close.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Robert Donovan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 65
전체 시간: 5,852
