주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 또는 2.8 GHz quad-core Intel Core i5. 2015년 10월 13일 출시.
LCD Inverter Power Backlight Cable
이미지
Hi, there. Wondering what’s wrong with this top LCD light (please refer to attachment)? As it won’t on when iMac is turn on, the other 3 LCD lights are OK. Is it LCD Inverter Power Backlight Cable is faulty? Thanks in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Thanks, Dan. I thought the image was uploaded together with the post.
의
댓글 달기
답변 1개
Reconnect the display making sure you properly seat the connections. Use some painters tape to hold the display. If you get an image tale a picture and post it. If you don’t plug in an external display does it show your desktop? If you can’t do that take a flashlight pressed on the display in a dimly lit room you should see a faint image of your desktop and/or do you see a slight glow from the display?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kenny Sim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 374
