주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
{A1706 / EMC 3071}—2017년 6월에 출시된 이 13" MacBook Pro는 최대 3.5 GHz Core i7(Turbo Boost 최대 4.0 GHz)까지 지원하는 Kaby Lake 프로세서를 탑재하고 있습니다.
MacBook Pro 2017 backlight issues
You have reported that the MacBook Pro backlight issues are caused by a delicate flex cable,
Apple announced Service Program will repair affected devices, which includes machines sold between October 2016 and February 2018 for free, this time repair program only cover 2016. My computer is 2017 product (13-inch, 2017, Two Thunderbolt 3 ports), it has back light problem too, Apple repair checked and ask for UDS$ 550 to repair, because they only free repair for 2016, why and what can we do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
You are not the only one that has faced this, you need to ask for a warranty exception as this is a design failure.
The window to get any relief is closing! Which is likely why Apple is now charging for the repair.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I’m having the same issue. Would you please be able to let us know How can we ask for warranty exception??
의 공유
댓글 달기
Same with my 2017 13-inch model, did you manage to fix it?
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
@khangneovip - You better hop into your vehicle and get your self to an Apple Store ASAP!!
Your time is very short in getting this fixed under the extended warranty program (review the Blue URLs I posted above) otherwise it’s out of your pocket! MacBook Pro 13" Retina (Late 2016-2017) Display Assembly were it would be free!
I’ve gotten the 2017 fixed a few times asking for a warranty exemption as they know the 2017 faced the same issue!
의 공유
Hey Dan!
I've had the same issue, called apple customer support and they've told me that only the 2016 model would be covered even though they know some 2017 models may experience this, insane. How did you go about this in store? I'd like to try to get it fixed asap!
의 공유
@clvidmar - The squeaky wheel gets the grease! Don’t accept No, make it a YES! Many country’s have longer (better) protection laws that the US! Find out what your protection is.
Press for a warranty exception, ask for the repair manager then the store then the regional managers. Write a letter to big Tim as well as talk to your local consumer protection groups, write a complaint as well!
But what worked a few years ago is getting harder as this system is getting close to the vintage listing when Apple wipes there hands of servicing the system
의 공유
댓글 달기
How can you fix the machine, or claim to Apple?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@joseandres26056 - Sadly the window is now fully closed for the 2016 and likely for the 2017 as well.
So that only leaves replacing the display assembly which is quite expensive! MacBook Pro 13" Retina (Late 2016-2017) Display Assembly
의 공유
댓글 달기
답변을 추가하세요
emma Chang 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 23
전체 시간: 5,829
