주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 초에 출시된 2015년형 Retina MacBook 업데이트 버전의 수리 정보 및 안내서. 모델 A1534 / EMC 2991
MacBook No Startup Disk?
Hello, I have a MacBook Retina early 2016 which I tried to reinstall the OS on however it told me there was no starting disk, how can I get one or install one? This MacBook has a soldered SSD and RAM, and no disk slot so I’m guessing its something I have to install. Thank you for your help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Looks like you can boot into recovery mode. First run Disk Utility and see if you can repair the storage unit. If not you may have to reformat the drive and then try installing a system.
If it were in a shop, they would try using an external drive to boot from and work on the storage.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
I repaired the hard drive, but unfortunately the issue still persists. What do you mean by "report the drive"? Also, I'm not sure if this has anything to do with the issue but the screen flashes to white and grey every 2-3 seconds before returning to normal. If you need a picture of it glitching like this let me know, I can upload one
의
Spell check error - corrected "reformat"
의
댓글 달기
These Macbooks are relatively prone to fail because of failing memory chips. Since it seems software "repair" didn't fix the issue, there's nothing else left but a board replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Colby Morris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 27
전체 시간: 1,370
