주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony GTK-XB5는 2016년에 출시된 Bluetooth 지원 고출력 홈 오디오 시스템입니다. 이 오디오 시스템은 블랙, 레드, 블루 색상으로 제공됩니다.
How to fix my power jack
이미지
이미지
이미지
이미지
I have tried to solder it back together but I am not sure if I have done it right can solder arc between it self as there is a small gap in the solder I did manage to turn it back on for a few seconds then it died then when I tried again there was a spark from the power jack
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
@andrewlang00 post some pictures of the jack and teh repair etc. with your question. Let's see if there was a solder bridge or similar that may have caused this. 기존 질문에 이미지 추가하기
@oldturkey03 added photos also I am very aware my soldering job is terrible hopefully the pictures help tho
It was fixed to the board better when I first tested it but taking it in and out has loosened the solder
댓글 달기
답변 1개
선택된 해법
It looks like these are "cold" solder joints, which means the connection between the pad and the pins are not good, which would explain the sparking. Try to touch your soldering iron to the pin and the pad and the same time to heat up both and then apply solder so it covers the pin and the pad for a flawless connection.
이미지
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Andrew Lang 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 354
