주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Super Nintendo Entertainment System(SNES) 또는 줄여서 Super Nintendo는 1990년에 Nintendo에서 출시한 16비트 게임기입니다. Super Nintendo는 당대 최고의 베스트셀러 중 하나였으며 오늘날에도 여전히 많은 팬층을 보유하고 있습니다.
No Power Issue SNES
My SNES has stopped working, measuring the output of the power cord, the max I got was 1 volt, does this mean it is the power cables fault? This all started when the console fell, so I have checked the insides of the console and the charger, the console looked completely fine on the inside. I tried to measure from the chargers transformer itself but I don’t know which parts to put my prongs on. Most likely I think it’s the cable, I don’t think it’s the power connector itself, I have measured around the same voltage on the console itself that I did on the power cable. On Continuity mode, I put one prong on one of the power prongs, one on the other side of the cable, no beeping.
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
We have found that this issue can be caused by using an underpowered AC adapter or power source. The problem can be resolved by using a licensed AC adapter. You can purchase one from the Nintendo Store. If a licensed AC adapter is unavailable, you can try using a different AC adapter that is rated as 5V/1A. Now i am sharing this helpfull answer No Power Issue SNES- apkbik
thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Connor Steffenhagen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 12
지난 30일: 28
전체 시간: 1,014
