주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서. 이 내용은 2006년 초부터 2007년 중반까지의 최초 Intel 기반 Mac Mini 모델을 다룹니다.
Mac mini 2007 dead
Hi everyone,
I recently bought a dead Mac Mini from 2007. But when I try to power it on, there is nothing, no light, no chime, not any sound from it. I took apart the logic board and everything seems fine. The charger is working because on the second one i have, it works perfectly.
Do you have any suggestions to measure with multimeter ? Because I’m used to laptops not Mac Mini’s. Thanks :)
Update (03/24/2022)
On the global photo, it’s at the top right
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
Can you take a second picture so we can at least read the logic board labels and the cap if its still intact in the location it was located.
의 공유
@danj hello, i removed the capacitor the motherboard is a 820-1900-A from 2006.
의 공유
It has the same size as the others next to it @danj
의 공유
@anthony10006 - Just because it looks the same doesn't mean its the same values.
의 공유
Yes i know. Unfortunately, i can’t find any schematic for this board :( @danj
의 공유
댓글 달기
답변 2개
선택된 해법
Le problème venait d’un condensateur en court-circuit. Maintenant le mac remarche mais il me reste à remplacer le défaillant.
The problem was a shorted capacitor. Now the mac works again but I still have to replace the faulty one.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
Have you tried just replacing the PRAM battery?
이미지
You may need to take the logic board fully out so you can inspect the other side. Look for a component that looks discolored or burnt. Often the electrolytic & tantalum caps breakdown. Mac mini 모델 A1176 로직 보드 교체
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
@danj Hi, thanks for your fast answer. Is it possible that the mac could not turns on due to an issue with the pram battery ? Also, as i saw, i didn’t manage to find some dead caps on the logic board, the only thing that i noticed it that a ceramic cap looks weird near the cpu, it is a bit brown not as usual. So i used my multimeter to test for continuity and i have a value of more than 1100 on the line and this seems weird. Thanks
의 공유
@anthony10006 - The older systems need the battery to work properly. I would start there.
의 공유
@danj hello, i found a dead capacitor and now the Mac works. But i can’t find a schematic for this model. Have you got one please ? It’s 820-1900-A for the board model. Thanks
의 공유
@anthony10006 - Sadly I haven't found any for the Mini's. Best to ID the cap's specs how about posting both images of the cap and the location on the logic board. 기존 질문에 이미지 추가하기
의 공유
@danj ok, i will send the image in the answers
의 공유
댓글 달기
답변을 추가하세요
Correia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 16
전체 시간: 688
