주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Subaru Legacy 6세대 모델은 2014년 시카고 오토쇼에서 처음 공개되었으며, 2015년형 모델로 생산되었습니다.
check engine light on code p700.
i got this check engine light everytime it rains . i scan the code and it show p700 . ( transmission failure ) however the car run okay no problem and after 2 days of doing running the check engine light will turn off.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
See if the diagram here helps. It's from the Outback Owners site.
https://www.suoutback.com/transmission_h...
의 공유
댓글 달기
답변 1개
선택된 해법
It could be a number of issues but when you said it mainly happens when it rains then i would put money on it being a bad connection in the wiring harness to the transmission. Maybe water causing a short circuit & then once it’s dried out the transmission control unit thinks the fault has cleared.
I would follow the wiring harness from the left side of the dash, through to the gearbox. Checking for any breaks in insulation & also the security of any connector blocks outside of the interior of the vehicle. I know the Subaru Forester has 2 BIG connector blocks on the top of the gearbox around the bell housing area. It maybe the problem lies in those. Google your transmission wiring harness & see what the photos show you.
Good luck
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
EDWIN CHAN MENCIAS 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 21
전체 시간: 686
