주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Socket 1366은 초기 Core 및 Xeon 시리즈 프로세서를 위해 설계되었습니다.
Does resettable fuse has direction?
Hi, Does resettable fuse has direction of installation ? Thanks
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
No, resettable fuses do not have a polarity.
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
Thank you 🙏 🌞
댓글 달기
no
”Comparing PTC fuses to one-time fuses Every fuse has an amperage rating and protects downstream circuit components from damaging overcurrents. Both one-time and PTC resettable fuses connect in series with the load and are not polarity sensitive. PTC fuses reset themselves, whereas one-time fuses open the circuit as a one-time positive disconnect and must be replaced before resuming operation. Both technologies require the removal of the overcurrent condition to resume normal operation. Due to this key characteristic, selection parameters differ — some of which are compared in Table 1.”
https://www.eaton.com/content/dam/eaton/...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
댓글 달기
답변을 추가하세요
Formingus 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 1,002
