주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Magic Trackpad 수리 안내서. 2010년 출시.
The pointer only moves vertically.
To be more precise there's only a narrow vertical band of the trackpad responding. Touching outside of this, central, band has no effect on the pointer.
I tried connecting it to another MacBook but with the same result. I’ve also tried to remove batteries and replace them with new ones and also to completely disconnect it but nothing.
The same thing happened a month ago, that time changing batteries solved the problem.
Do you have any idea?
Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The sensor plate has become damaged. Did you drop it or sit something on it that could have damaged it?
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
No, indeed I left it on my desk for one week during the holidays and when I came back it wasn't working.
의 공유
@nikdef - Other than trying a fresh set of batteries they just isn't anything that you can fix (the Magic Trackpad2 has a sealed in battery).
의 공유
It's just weird that it is sensible only in that narrow band. Thank you anyway.
의 공유
@nikdef - Maybe the battery failed and pressed against the panel from the back side damaging it. Time for a new one.
의 공유
댓글 달기
답변을 추가하세요
Nicola 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 19
전체 시간: 382
