주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S9은 모델 번호: SM-G960XU로 식별됩니다. 2018년 3월에 출시된 9세대 Samsung Galaxy Series 입니다. 색상은 라일락 퍼플, 미드나잇 블랙 및 코랄 블루가 있습니다.
Replacing display, should I replace frame as well?
I have a Samsung Galaxy S9 and I'm planning on replacing the display as the one currently on the phone is cracked and doesn't receive touch input on most of the screen surface area.
On the guide it is mentioned that if the frame itself is damaged/dented, it could lead to the new display damaged as well. The S9 I'm going to be working on has had some damage and I'm hoping if anyone here could give me some advice on whether I should go ahead without getting a new frame or replacing the frame and the screen.
I've included photos of the display and frame with and without the screen being on.
Display images:
이미지
이미지
이미지
이미지
이미지
이미지
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
This would make the repair easier, but more expensive. Also, if you only replace the display, you will need to make sure you have enough spare adhesive. Display replacement guide: Samsung Galaxy S9 디스플레이 교체
이 답변이 도움이 되었나요?
점수 3
댓글 7개:
So would just replacing the display be alright?
Do you think that the dented frame could interfere with the display and possibly cause damage again?
I don't mind if it's more difficult, but I would like to keep the price cheap. The main thing for me is making sure that the display has no chances of breaking again, the screen on its own is pretty pricey!
@jermia Yes, this would be totally fine. You will need to be very careful to prevent damage.
@guardian10 Hey thanks for the advice! In what aspect do you mean to be careful? Do you mean in general during the whole process or just making sure that I'm careful for a particular step?
Also the frame dents should be straightened out with pliers or a similar tool.
@jermia The whole process
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Jeremy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 27
전체 시간: 1,711
