주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
로지텍 MX 마스터 2S 무선 마우스 수리 및 분해 정보입니다. 2017년에 출시되었으며 모델 번호(M/N) M-R0066 또는 부품 번호(P/N) 810-005769, 910-005138, 910-005137 또는 910-005131로 식별됩니다.
Sensor no longer picking up movement.
All other functions of the mouse work normally, it just will not pick up movement.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 27
댓글 3개
Ok this is weird - the same thing happened to me too, on the SAME DAY!!
의
Amazing fix.
의
I'm having the same problem. I found this website and thought of removing the mouse cover. With the cover open, the mouse works fine. If I reassemble the cover, it stops working. OMG
A mi me ocurre lo mismo. Encontré esta web y se me ocurrio quitar latapa del ratón. Con el ratón abierto, el raton funciona correctamente. Si vuelvo a ensamblar la tapa deja de funcionar. Por dios!!!
의
댓글 달기
답변 2개
선택된 해법
This happened to me last week on the same day as you posted your question, spooky!
To fix it I found this repair guide, which suggests that the gesture button can get stuck if it gets pressed... wrong.
I used this teardown guide to open the mouse up with an iOpener to soften the sticker adhesive and a metal spudger to peel it up, then broad tweezers to prevent tearing or grease from my fingers, I followed Steps 1-2. Then the first part of Step 3 to remove the black screws. I tested the button and its mechanism. Both seems to actuate fine, so I reattached it without tightening fully to give it a little wiggle room.
Once I reassembled the mouse and used the iOpener to soften the adhesive and smooth it back down the the metal spudger, it worked as good as new, if a little more crinkly on the bottom, which is undetectable in normal operation.
이 답변이 도움이 되었나요?
점수 27
댓글 17개:
I had the same problem, following these steps I solved it. Thank you!
의
works like charm
의
It helped me a lot! I just untightened the screws of gesture button twice, in first time it was also helpful, but after one hour the problem started again, after the second untightening is it good. Thank you a lot! My wife has a gold standard "new" mouse after that fix :)
의
Perfect, thank you so much... Even our shop told me my mouse was dead... And need to be changed.
With you tips, my mouse is now working as usual !!!
Thanks
의
Jest letting people know that this solves the same issue for the original MX Master!
의
댓글 12개 더보기
댓글 달기
Well my friend this video might helpful for you.
https://www.youtube.com/watch?v=VbgN4Ywt...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Brentleigh Ward 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 14
지난 7일: 80
지난 30일: 379
전체 시간: 19,166
