주요 콘텐츠로 건너뛰기
Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
113 질문 전체 보기
How not to loose TrueTone screen replacement?
Hi everybody,
I've already saw different post that answers part of my question "Will I loose TrueTone and autobrightness with a screen replacement". But I want to know if the part that iFixit sells is a virgin part or not (will or will not loose TrueTone...etc).
What's the specific reason that this happens? If I get a screen from a used MacBook, will I loose this functionality? Has anyone tried or have experienced this?
Thanks for he help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If you get a new virgin display then you will loose Brightness, FaceTime camera & True Tone services. The issue is the display needs to be calibrated as they requires the system to be complete. Frankly, I really don’t see why Apple makes this hard if not to discourage repair.
If on the other hand getting a recycled display (which is what I use for my customers) then you don’t loose anything! As the calibration was performed and the settings are stored within the displays T-CON logic.
Here's the needed part MacBook Pro 13" (A2338, Late 2020) Display Assembly - Used! and here's the guide to put in on MacBook Pro 13" Two Thunderbolt Ports Late 2020 디스플레이 어셈블리 교체
MacBook Pro 13" (A2338) Display Assembly 이미지
상품
$539.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks, but is the part that iFixit sells virgin or not?
@benmerino - The link I posted is for a Used display, Not a Virgin one which would then need calibration which you can't do.
댓글 달기
귀하의 답변을 추가하세요
Ben Merino 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 31
전체 시간: 474
