주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox Elite Wireless Controller Series 2는 2019년 11월 4일에 출시되었으며, Xbox One, X, S 콘솔은 물론 Windows 10/11을 실행하는 PC와 호환됩니다. 모델 1797.
Left stick drift and delayed response time
The left stick is always drifting. Sometimes it's not noticeable in game but in menu it will cycle up consistently. Sometimes a quick flick fixes it. Other issue is you press the stick in and the action is not always crisp, there is a delay
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
connect the controller to a pc or laptop then open this site, https://gamepad-tester.com/. it will show you how bad its moving. if bad it needs the analogue stick replaced.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hey Tyrone! I was able to fix it by opening up my controller and cleaning the sensors on the left stick. This helped me a ton.
When you get to step 11, make sure you move both the green plastic housing for the left stick's sensors. The one on the right controls the X axis and the one on the bottom controls the Y axis. You most likely need to clean out the bottom sensor with some canned air and it should work.
Saved me a few hundred bucks by not buying another controller! Hope this helps out!
Xbox One Elite Series 2 컨트롤러 아날로그 스틱 쏠림 현상 수리 방법
이 답변이 도움이 되었나요?
점수 1
댓글 달기
i replaced the analog stick but the problem persisted. i think it might have something to do with a capacitor
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tyrone Palmer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 44
전체 시간: 4,464
