주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Screen Flickering
From what I have determined through testing, the screen will flicker (more accurately it appears like an old film). This occurs when the main processor is in use. The flicker goes away when watching a dvd. OS is 10.5.8, same issue occurs with 10.4.11 This board has the known ram slot issue. How can I fix the flickering?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
What is your question?
의 공유
Edited to be a question to satisfy Nat.
의 공유
댓글 달기
답변 4개
선택된 해법
Hi! I'm wondering if this happens in all screen resolutions and color depths? You might try switching to a different resolution just to see. While unlikely the answer (due to the fact you've tried two different operating systems), I have seen machines go into odd screen resolutions when a DVD is played, or when external video is used (I assume to accommodate the limitations or specs of the external image). Also, I always do PMU and PRAM resets on malfunctioning machines, just to rule that out, because funky settings in PRAM can cause any number of problems. Hope that helps.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
의 공유
댓글 달기
your anwer is,wait for it ........... there is nothing you can do about the
Apple guys diasbled the solution url for that problem because of the product line factory problem they failed to fix.and that is the reason why you no longer find them on the shelves,they were dicontinued for that same reason.Shame on you Apple
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Try an other Inverterboard that controls the backlighting and so the flickering. Maybe some cables are on wrong position. Check temperature of the CPU with iStat Pro widget. Is there a flickering when you connect a Display to the DVI Port?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Corrected spelling
의 공유
[url=http://slot-888.co][color=#e1e1e1][size=1px]slot[/size][/color][/url]
의 공유
댓글 달기
Kenapa skrin menjadi berkelip kelip
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
stacywebb 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 4,635
