I put 220 volts on it and the electronic map burned out
type 5514 .. I put 220 volts on it and the electronic map burned out
The transistor has burned out.. where can I find its type and number
Update (05/11/2022)
Update (05/11/2022)
i think two transistor problem 😓
좋은 질문 입니까?
댓글 4개
@maheralafndy post some good picture of the damaged board and component with your QUESTION. That way we can see what you see and hopefully find what you need. 기존 질문에 이미지 추가하기
oldturkey03 의
@maheralafndy can you post a picture that was taken straight to the board? Makes it easier to look at the components and traces as well as the other side. Wash the board off with some isopropyl alcohol or similar and a soft brush. Looks like some major damage and I wonder if this is not more than just a transistor....
oldturkey03 의
@maheralafndy Could you fix it? I've made that mistake too.
Kilic 의
hello ... no ..I buy my comfort and got a new one ..11$ 😅 philips
maher alafndy 의
