I can’t unscrew the screws on the bottom side, how do I do that?
When I try to turn the screwdriver, the screw doesn’t even move. I guess they are glued or something.
좋은 질문 입니까?
좋은 질문 입니까?
@knoni12 check your charger with a multimeter make sure that it works properly. After that check to see if it charges the battery. Measure at the battery connector to see if you get power there when you plug your charger into the 2DS. If you do not, it is possible that you have a bad charging port. this model is known for bad solder connections on the port or a bad fuse (Fuse F1 located right next to the port is the charging fuse) on the motherboard. You will have to try and remove those screws. They are not glued by factory unless somebody glued them in after. What you need is a good Philips screwdriver and some force to remove those. Make sure that the screwdriver is fitting well otherwise you may strip the screw head.
Check continuity on the fuse with a multimeter and if it fails please replace it, do not use a jumper or similar since that is a recipe for your 2DS to die if anything happens. Any of these fuses will work.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 74
댓글 1개
Hi @knoni12,
Please do not create new questions regarding the problems with your device.
Update your original question by clicking on Options > Edit in your question.
That way any and all answers will be kept together with the question.
Moderator.
jayeff 의
