주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oral-B Triumph v2는 전기 칫솔 시리즈입니다. Oral-B BLACK 7000 패키지에 포함된 타입(이 가이드에서 묘사되고 사용됨)은 3762 타입입니다.
Runs down and stops in about a second
My toothbrush runs down and stops in about a second. I fixed the problem a few months ago by unsoldering and then resoldering the battery. I have checked the battery voltage during the switch on, slow down and stop phase and it remains constant at about 3.7V so there would seem not to be a problem with the battery. When the problem occurred before I found that bypassing the MOSFET caused the motor to run normally at full speed, so this seems to be a microprocessor issue. I have tried resetting the brush by holding the power button for ten seconds. There is no water inside.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
Fixed - there is a polyfuse marked PP which is Bourns MF-PSML300 rated 3A and it was dropping several volts. Bypassed fuse with multimeter on current setting, toothbrush works and meter reads 0.5A so fuse clearly faulty. Bridged fuse with solder for permanent fix. It is possible to buy replacement fuses but they are expensive and not easy to fit.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
removing that "PP" fuse and bridging it totally worked, thanks!
의
Is the fuse next to the PP with an E of quite a few amps?
의
댓글 달기
bypassing a fuse is never a good idea for a long term solution. SMD parts are not simple, but this part is big so it should not be a big problem.
These are 0.18¢ each - min quantity 10.
https://www.aliexpress.com/item/22518327...
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I had the same problem with a similar OralB toothbrush. It would charge and start, but run down in 1-2 seconds. Battery seemed fine, but the polyfuse measured 3-4 Ohms. That's completely out of spec. So I replaced it with a tiny strand of wire. Works again as before.
Thanks for the pointer!
의
That's a 1206 package, OEM is an 0805
의
댓글 달기
답변을 추가하세요
Tim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 28
지난 30일: 96
전체 시간: 15,332
