주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G533 무선 게이밍 헤드셋의 수리 및 분해 정보입니다. G533은 모델 번호 A-00072를 통해 식별할 수 있습니다. 2017년 1월에 출시되었습니다.
Mic doesn’t work
My mic doesn’t work all the time.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
My guess is an intermittent mike may be the result of wire damage. You may have to carefully disassemble the headpiece containing the mike and wiring to examine for wire damage, especially at the point(s) of flex. If visible wire damage isn't seen then a continuity test to each wire of the mike is needed to determine which wire broke inside insulation. Soldering skills would be needed to repair wire damage. If you find and repair damage, try it first before reassembling everything, exercising mike movement to ensure the repair is complete.
의
댓글 달기
답변 1개
This is not a good question because it gives no history or info relative to when and what was tried to troubleshoot it.
Best guess is a broken lead wire, usually close to an end or connector connection.
Least likely is something internal to the headset unless the mike boom has been move a lot to extreme positions.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
afyuqnjklpi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 38
전체 시간: 3,926
