Connecting to Modern TV
Hey! I was trying to connect my NES to my TV using the composite ports, but it won't work. Any suggestions?
좋은 질문 입니까?
좋은 질문 입니까?
If the TV has composite ports and the NES has composite ports and you connect the RED to RED, WHITE to WHITE, YELLOW to YELLOW and set the TV input to the composite ports everything should work.
If it does not, then either the NES isn't transmitting, the cables are bad, or the TV isn't receiving.
To figure out which is a matter of substitution.
Connect to another TV. If it still does not work, then it probably isn't the TV.
Connect a different set of cables. If it still doesn't work, then it is probably your NES.
해당 답변은 도움이 되었습니까?
Thanks, I will try it.
24 시간 전: 7
7일 전: 22
30일 전: 114
전체 시간: 825
댓글 1개
Hi @a_commodore_fan,
What is the make and model number of the TV?
jayeff 의
