주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1985년 닌텐도(Nintendo) 사에서 북미에 출시한 게임기인 닌텐도 엔터테인먼트 시스템(Nintendo Entertainment System), 모델명 NES-001입니다.
Connecting to Modern TV
Hey! I was trying to connect my NES to my TV using the composite ports, but it won't work. Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hi @a_commodore_fan,
What is the make and model number of the TV?
의
댓글 달기
답변 2개
선택된 해법
If the TV has composite ports and the NES has composite ports and you connect the RED to RED, WHITE to WHITE, YELLOW to YELLOW and set the TV input to the composite ports everything should work.
If it does not, then either the NES isn't transmitting, the cables are bad, or the TV isn't receiving.
To figure out which is a matter of substitution.
Connect to another TV. If it still does not work, then it probably isn't the TV.
Connect a different set of cables. If it still doesn't work, then it is probably your NES.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks, I will try it.
의
댓글 달기
I had the same issue with my LG tv. I bought this CONVERTER from amazon and it works great! still cant play duck hunt on modern tv's though =(
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I know. It's an unfortunate side affect from switching to LCD/LED. I might buy the converter.
의
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 17
지난 30일: 45
전체 시간: 4,108
