주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft의 Surface Laptop 2는 2018년 10월에 출시되었습니다.
Stuck in automatic repair loop
I have a Surface 2 (model 1572 according to the box) that came in as a donation. It is stuck in an automatic repair loop. It turns on, preparing automatic repair, shuts down, and continues the loop.
I've tried holding the Vol+ and power, but will absolutely not respond with the Vol+ depressed.
I'm at a loss what to do. Please help...
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Hi. Try reinstalling Windows from a USB drive. The issue is most likely corrupted Windows files.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Yes, I understand that.
The problem is I cannot get it to load the UEFI screen, cannot change a boot order, or get it to respond in any manner.
의 공유
I’d try it, some PCs default to USB if one is plugged in OR give you the option to press a key for USB. If you have already tried doing that, I unfortunately don’t know what you need to do to fix it.
의 공유
댓글 달기
답변을 추가하세요
nelmarkj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 1,033
