주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 60D는 18MP DSLR(디지털 일안 반사식) 카메라로, 회전형 LCD 화면을 갖추고 있습니다. 이 카메라는 2010년 8월에 출시되었으며, 카메라 전면에 인쇄된 EOS 60D를 통해 모델을 식별할 수 있습니다.
60D quick control menu not visible
I just bought a Canon 60D and while i was setting it up for use as a webcam i tried to integrate either EOS utility 1 or 2 with OBS it broke my camera. It didnt respond so i turned it off and didnt think much of it.
A while later i turned it on again and whenever i switch to any other mode than movie the screen goes black, i can take pictures and look at them i can also go into the menu but i cant for any reason look at (i think its called) the quick control menu with all the camera settings like shutterspeed.
Anyone know of this problem and how to solve it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
If you're having trouble seeing the 60D's quick control menu, it may be because you have the camera's LCD brightness turned down too low. To fix this, press the INFO button and then use the Quick Control Dial to adjust the brightness level.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
i can see the menu and photos clearly but not the quick control, this is not a brightness issue but thanks
댓글 달기
답변을 추가하세요
Mark William 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 452
