주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto G7 Power 스마트폰의 기기 페이지 및 수리 안내서입니다. 이 스마트폰은 2019년 3월에 출시되었으며, 모델 번호는 XT1955-1, XT1955-2, XT1955-4, XT1955-5, XT1955-7입니다.
How to apply adhesive when reassembling device?
Im planning on following this guide to replace my usb daughterboard. when im reassembling the device, do i just apply tesa tape to the outer edges of the phone, and maybe a couple strips on top of the daughterboard cover? i just dont want to place it in the wrong place and risk damaging something should i need to reopen the phone again
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
For the purposes of sealing the phone as well as possible, I always prefer using pre-cut adhesives rather than tape that you have to trim to fit. I poked around a bit and it seems the adhesive for your particular phone isn't exactly in great supply. On Amazon all I could come up with were replacement back covers that come with adhesive, although to be honest the price wasn't all that bad - around $12 USD.
The adhesive guide referenced in the daughterboard guide should work fine for installing your precut adhesive if you end up getting some. Just make sure to clean both surfaces really well with high purity isopropyl alcohol (not the normal 70% stuff we usually have around the house).
The adhesive pretty much always gets applied to the phone itself, not the cover. Check the shape and match it up to where it's going to sit to make sure you get it in the right orientation. When you go to fit it, make sure all the connectors and cables and everything are laying flat so the adhesive will sit in place correctly.
Once you've peeled the backing and put the adhesive in place run around the edges with the flat side of a spudger and press it firmly into place so it won't come up when you peel the rest of the backing off.
That's about it; if you have any questions feel free to ask.
Best of luck with your repair!
EDIT: I found a couple of listings for the adhesive on eBay, but both sellers were out of stock so I didn't mention them. However, it occurs to me that you can look at the listing to see exactly where the adhesive actually goes so if you wind up using the Tesa tape you'll have a guide to go by. Here's a picture from the listing that might help.
이미지
Here's the listing it came from, just in case you want to contact them and see if they plan on getting any more in stock.
Motorola Moto G7 / G7 Power LCD Adhesive Sticker Tape Repair Tool 1 or 2 Pcs
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Maxim Jessuin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 913
