주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AirPods Max 무선 노이즈 캔슬링 헤드폰에 대한 수리 및 분해 정보입니다.
Are earcups swappable/replaceable?
Given that the right earcup houses the main electronics and battery and it’s quite simple to remove the earcups with a SIM ejector tool, is it possible to take the left earcup to be paired with a different right earcup, or vice versa? What happens to the serial number?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 2개
가장 유용한 답변
Hi,
Yes, you may mix & match them as long as you have one right and one left.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Eat cups are replaceable, but the left side cannot go on the right side and vice versa. You can buy them directly from Apple or on Amazon.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I was talking about the aluminum earcup pieces. I suppose you understood what Apple calls "Ear Cushions". For anyone who's wondering about this, you CAN swap the earcups between different APMs, even different color ones, (you need L and R).
Context: I had a dead pair (R one has battery while the L has BT connections). The LED didn't light green when plugging them to power. This meant ONE of the earcups OR the headband was busted. I don't really know if there's a way to know which side it is without access to another pair of APMs and mix n' matching by disconnecting earcups with the SIM ejector tool.
Apparently, the R cup doesn't light up by itself if it's not connected to a L w/ headband. I took a risk and bought a used R from someone on eBay and was lucky that it was precisely the R side that broke, Maybe the known condensation issue or durability issues. But oh well, while this fixed my APMs which I absolutely loved, I haven't been able to use them as before because I'm scared that they may break again...
의 공유
댓글 달기
답변을 추가하세요
Alejandro Ibarra 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 31
전체 시간: 2,169
