주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
16, 32 또는 64 GB 저장 용량으로 출시된 3세대 Apple iPad 4G 모델의 수리 안내서, 분해 및 문제해결 정보입니다. 2012년 3월에 출시되었습니다. 모델 번호 A1430(GSM, AT&T) 또는 A1403(CDMA, Verizon)으로 식별할 수 있습니다. 수리를 위해서는 열을 가하고 조심스럽게 들어내는 과정이 필요합니다.
Why is it not charging?
So basically I haven't used my iPad in about 2 years or so. I recently found it in my drawer. I tried charging it and sometimes it gets to the low battery and black background screen. I left it for about 2 hours or so, and it didn't work, so I tried another charger, and it still didn't work.
TL;DR: Found my old iPad, put it in charge and it didn't work, even with a different charger (waited for around 2 hours).
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@xsinqq replace the battery. It is most likely discharged below its threshold iPad 3 4G 배터리 교체
의 공유
댓글 달기
답변 3개
It is incredibly common for the charge port to be dirty.
Try cleaning it (carefully) with a toothpick or a toothbrush and some alcohol preferably isopropyl.
That said there's still a good chance it's the battery
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Are you using a charger with at least 2a output? Phone chargers are useless for iPads. Also after two years the battery may be beyond help. Maybe could do with a new one if you want it working again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If it has been sitting idle for some number of years it would not be unheard of for the battery to be worn out. Lithium Ion batteries don’t like being left dead for long periods of time and is so discharged it just isn’t functional any longer.
Make sure when its charging you have it connected to the original charger, or one rated for at least 10 watts. If it is an Apple charger it will say on the brick. Otherwise wattage is Voltage x Amperage. iPads can take a good hour to power on from that level of dead if they are going to power on at all.
If that doesn’t work, then a new battery is in order.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shubhankar Shreyash 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 18
전체 시간: 409
