Replaced Fan Still Doesn't Spin
Hi and Thank You in advance for your advice. I love my MacBook unibody mid-2010. I've replaced the fan before and all went well. I replaced it again when it stopped working with Macs Fan Control. However, the new fan isn't spinning. What else could be the problem?
Thanks!
~Lucy
좋은 질문입니까?
Do you still have the original Grey CD's that came with your system? If you do locate the one marked diagnostics. Restart your system with it let us know what the diagnostic error code came back.
DanJ 의
Thanks for the quick reply! I don't know if I do. If I don't find the CDs, is there another way to run diagnostics please?
Lucy Sock 의
@Lucy Sock - What is the OS-X/macOS release your system is running?
DanJ 의
@danj High Sierra
Lucy Sock 의
@Lucy Sock - OK, let's give this a try: start your system and press the D or try Option - D key to enter into the onboard diagnostics (or internet connected diagnostics). I'm not sure this will work but its the easiest to do.
Reference: Mac startup key combinations
DanJ 의
댓글 4개 더보기
