주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 11월 iPad Pro 라인의 에디션으로 출시되었습니다. 모델 A1980.
Do you think this repairable?
I didnt use enough heat to get the ambient sensor off and it separated.
I am getting the message that says Face ID cant activate, so I'm not sure if that's because of my installation is not right, or if its indeed because of the ambient sensor?
Can this even be repaired?
Attached is what the separation looks like from the sensor.
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
This cable is needed for FaceID to function. It may be repairable with micro-soldering, but it looks like the traces were ripped from the cable, so it would be very difficult.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Bummer! I know that the sensors are paired to system board so my only option would be to micro solder..
thank you! I needed that confirmation!
댓글 달기
If the pads have been ripped off then you probably have no chance. You might have to bite the bullet and go without face id. That or go down the expensive apple route.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chris Weger 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 53
전체 시간: 411
