주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
마이크로소프트의 4K 게임기 Xbox Series X 관련 수리, 분해, 문제해결 정보. Xbox Series X는 2020년 11월 10일에 동반 콘솔 Xbox Series S와 함께 출시되었습니다.
Which Thermal Paste Brand?
Just curious as to which thermal paste would you use? I used Arctic Silver. That should be fine right?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Personally I use Artic MX-6 for the APU and the spread technique to ensure even coverage. For the RAM chips and SSD I use thermal grizzly advanced (I buy 30g for one console) at around 1.5mm in thickness using the applicator included. The SSD will need it on both the drive it's self and the metal drive cover.
의 공유
My Xbox series x need a new HDMI part in the back of the console how much is it
의 공유
댓글 달기
답변 1개
선택된 해법
Hi
This is quite a unpopular opinion but aslong as you are using a good quality thermal paste it doesn’t really matter
Most people will use arctic silver or thermal grizzly but I use jut whatever I have on hand as thermal paste is quite subjective for what you are using it for
Some might say one is better that the other for GPUs or lidded or unlidded CPUs ,it’s really what’s you personally find works
So aslong as it does the job you should be all good to go!
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 2
댓글 5개:
So even for the Xbox it wouldn’t matter? Be the exact same as a desktop CPU I guess.
의 공유
@kain05
Well kinda
All thermal pastes do the same thing really
It’s what ever people finds works for them :-)
의 공유
Yeah I kind of figured. Just read somewhere, that someone said you shouldn’t use Arctic Silver on the Xbox so was curious. I have Cooler Master and Arctic Silver. Anyways, thanks for the reply.
의 공유
@kain05
Your most welcome!
If you need anything else please ask:-)
의 공유
I've put arctic silver ceramique2 on probably 60+ series x post HDMI replacement at this point. Works great on them as it does for everything. Don't use it in a ps5 obviously. That liquid metal is a must, but also doesn't need replaced anyways unless you accidentally spill or wipe it off
의 공유
댓글 달기
답변을 추가하세요
Kane 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 17
지난 7일: 84
지난 30일: 201
전체 시간: 10,204
