주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy A72는 2021년 3월에 출시된 중급 USB-C 스마트폰입니다. 90Hz Super AMOLED 스크린, Snapdragon 720G 칩셋 및 6-8GB RAM을 제공합니다.
Samsung A72 Black Screen
So I make it clear and short.
My screen broke after I dropped my phone, I changed the screen and everything was fine at first. When I put the cover the screen started going black (touch and everything works fine though).
I got rid of the case after the service shop said there is no problem with the new screen. I noticed that when a certain area was pressed the screen went off (added a photo for illustration)...to turn it on I had to press power button couple of times. Until it just stopped turning on.
I sent to that same service shop they changed the screen but it would turn on again.
Phone still vibrates and everything its just the screen. Any idea what it could be??
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
@drein just to clarify, it has the same symptoms even with another screen? Try to add your piscture to your QUESTION by using this guide 기존 질문에 이미지 추가하기
Yes, same symptoms. Screen is black but phone works!
댓글 달기
답변 1개
가장 유용한 답변
With it happening with two different screens it is possible that the FPC connector on the board has been damaged since it doesn't work at all now. Sometimes the new screen FPC connector can be slightly too big and cause damage, or they can come loose off the board if disconnected improperly. You could always try another screen, but I believe it would most likely be related to the connector on the board or smoother board issue.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks a lot for your answer. As far as I understand seems like it only needs some soldering in the connector part.
댓글 달기
답변을 추가하세요
drein 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 1,379
