주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
9월 20일 출시된 Apple의 2019년형 메인스트림 iPhone으로, 6.1인치 LCD 터치 스크린, 듀얼 카메라를 탑재했으며 6가지 색상으로 출시되었습니다. iPhone XR의 후속 모델입니다.
Problem after update to ios 16
hello everyone after updating to ios 16 my screen stopped working properly I tried to install ios 15 but the phone after the attempt would not turn on all the time glowing logo apple , it was lying like this all night and this morning I managed to install ios 16 but unfortunately there is still a problem with the screen , I know that the screen works because on ios 15.6.1 it worked normally for me only after the update it broke in what is the problem? i also do not have original screen. There also is some error messege in 3utools the error is panic cpu x caller crash reason problem conecting cpu and peripherals if somone knows thanks for answer.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 8개
iOS 16 kills all aftermarket screens with iPhone 12s and up
의 공유
@aiman101 so iPhone series below 12 are good to go?
의 공유
No mine is messed up iPhone 11
의 공유
My iphone11 stopped working completely. I was resolving issue with support and now my phone is brick. It doesn't power up at all.
의 공유
It all works now with latest ios16 update.
의 공유
댓글 3개 더보기
댓글 달기
답변 5개
선택된 해법
Replacement screens will no longer work on IOS 16, either black screen or touch issue, confirmed with iPhone 13 mini this day, worked great, but after the IOS 16 update the touch stopped working.
이 답변이 도움이 되었나요?
점수 5
댓글 4개:
This has happened to my daughters iPhone 11,she did the IOS 16 update last night and now her touch dosnt work,it’s a replacement screen too,any idea how to fix it please?
의 공유
Had my 12PM screen replaced 3 months ago, did the ios16 update yesterday morning, my screen went black. I had no idea you had to actually go to an apple repair shop to get an actual apple screen until AFTER i paid $220 to get my screen repaired 3 months ago. Had to go yesterday to an authorized Apple repair shop and pay $330 and now my phone works like new.
의 공유
The only solution is Apple will fix it through a update, or get an original screen, it's just another way for Apple to milk more money from their customers, and to symbolize third party repairs as something bad.
의 공유
The fix is to have your phone updated before you replace your screen. Verify you have used a knowledgeable tech to replace it. Afterwords use the same tech to repair your software. Apple is and always has been a proprietary company. It doesn’t mean there are no work around.
의 공유
댓글 달기
Either a corrupt download or apple has cocked up the update again, which they do all the time. Try a hard reset first. If you have your data backed up try a restore. If not try and install it again with 3u tools. If none of that works you may have to wait until apple fixes the problem.
이 답변이 도움이 되었나요?
점수 4
댓글 7개:
I installed ios 15.7 and everything works normally I tried ios 16 again but it still didn't work properly for now I will go back to 15.7 and wait for another update
의 공유
@swdrbb any update about this ? do you manage to fix the issue by back to 15.7 ?
의 공유
@frisha_frish93 I installed ios 15.7 and it works normally
의 공유
This exact thing happened to me I am on iOS 15.7 right now. I can’t go to iOS 16 without my screen going completely black
의 공유
What website could I use to go back to iOS 15.7?
의 공유
댓글 2개 더보기
댓글 달기
I have ios 16 but the problem is that after the update the screen stopped working properly and in 3utools show error panic cpu x caller crash reason problem conecting cpu and peripherals
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Try hard reset first
의 공유
댓글 달기
Apple users should now start seeing the iOS 16 update on their iPhones. Just go to Settings> General> Software update and it should reflect. In our case, we saw an update for iOS 15.7 first, and then below that an option to upgrade to iOS 16. Apple's iOS 16 update is adding a new passkey feature.
Hope You Find This Useful,
Peter
이 답변이 도움이 되었나요?
점수 0
댓글 달기
im using iphone 11, right after installing ios16 . my iphone screen become 'ghost screen' . i can't use my iphone preperly the screen is moving and dragging everywhere . i was reset my phone more than 3 times . i have change the screen before with the third party provider. Is that the reason of this issue ? any idea to fix this ? do i need to go to apple to change original iphone screen ?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
you need to install an older version of ios that is 15.7 and it will work
의 공유
I have managed to downgrade to 15.7 using 3uTools. Now the touch screen works.
Step 1: Place the phone in DFU mode
Step 2: Access "Easy flash" menu of 3uTools
Keep in mind that this method will erase everything on your phone.
의 공유
댓글 달기
답변을 추가하세요
Jakub 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 35
전체 시간: 18,934
