주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mi 11은 6.81인치 쿼드 커브드 AMOLED 디스플레이, 108MP 후면 카메라, 디스플레이 지문인식 센서 및 4600mAh 배터리를 탑재한 Xiaomi의 플래그십 스마트폰입니다. Qualcomm Snapdragon 888을 최초로 탑재한 기기이며, Android 11 기반의 MIUI 12를 실행합니다.
Does anybody know this part?
Hello guys,
i need the part from the picture to repair my Mi 11 Ultra... it's a metal bracket / clip wich hold's the flex-cabel from the back-display on the mainboard. Does anybody know what's the exact name for this part, or can someboy tell me where i can buy it!?
Kind regards,
David
이미지
이미지
Update (09/15/2022)
I have found it, thanks guys!!!
If anybody need's the same part, here it is:
https://www.aliexpress.com/item/10050047...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
My educated guess is that this is the battery connector bracket. Mi 11 Screen Replacement guide has a similar part that is shown in step 9. I can't seem to find a place that sells it specifically, but I would be willing to bet that you could find it if you search eBay.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thanks for your information! Now I know the connector type is called "fpc" and I can search for it. Do you think it's possible to glue the connector on the mainboard or to stick it with a heat resistant tape?
의
댓글 달기
It's a clip to hold the fpc connection in place. As long as the connection is seated properly you could get away without it if you can't find another. Through normal use the connector shouldn't move unless the phone suffers a heavy drop.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Kuki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 725
