주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
De'Longhi BCO430 커피 센터는 펌프식 에스프레소 머신과 10컵용 드립 커피 머신이 결합된 제품으로, 우유 거품기(frothing wand)가 포함되어 있으며 은색과 검은색으로 구성되어 있습니다.
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
이미지
이미지
이미지
Did these images come ok?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
가장 유용한 답변
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 1
댓글 8개:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
의 공유
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
기존 질문에 이미지 추가하기
의 공유
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
의 공유
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
의 공유
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
의 공유
댓글 3개 더보기
댓글 달기
These coffee makers often are similar. Compare to Saeco Magic Capuccino SIN017 보일러 분해 and Starbucks barista , perhaps it helps. Good luck!
Starbucks Barista 이미지
안내서
Starbucks Barista 분해도
난이도:
조정
Saeco Magic Capuccino SIN017 보일러 분해 이미지
안내서
난이도:
조정
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Pics attached - this is how far I could get
Update (10/08/2022)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Update (10/08/2022)
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
liluet_hernandez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 517
