주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
*LG 휴대폰 충전용 USB Type-C 케이블 어셈블리 *충전기 본체는 트래블 파워 어댑터 EAY64469128입니다
How to fix it?
Not able to charge my phone
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Hi
Cables can be repaired but a lot of the time it isn’t worth repairing as with cables they struggle to last due to how they are used and how compact they are but it really depends what’s wrong
If it’s not charging make sure your device is plugged into a wall adapter that’s is compatible with your cable
It could also be damage related too so you will probably have to take the end off and desolder the cables to the pads that they belong to, the only issue is this is very hard and it could be a connector issue too so if you don’t know what the issue is for sure you could find yourself going down a rabbit hole
So my advise would be to ether dell or recycle the cable and buy a new one
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Repair my usb phone cable
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shubhashis Kayal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 372
