주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년 Harmonix에서 출시한 Wii 게임, The Beatles Rock Band용 드럼 세트 액세서리입니다. 이 수리 안내서는 드럼 세트의 특정 부품을 수리하거나 교체하는 데 도움을 드립니다. 모델 번호 NWDMS3로 식별할 수 있습니다.
Anyone know the name of this part
My drumkit the bandhero model and there's 2 purple audio inputs for the bass drum but mine are broken does anyone know how to find the name to but the replacement part or does anyone know a fix looks like it's got 3 pins
Update (09/21/2022)
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
CJ Allison I figure you are looking at the 3.5mm purple connectors. Some places list them as 3.5mm audio jack others strictly as 3.5 mm phone connectors. Not sure where to get the ones that are originally intended for your circuit board but you can replace those with other ones. The main issue is going to be dimensions and location of the contacts. Get some calipers are equivalent and measure the connector. The go check with places like this. There might be some that will come close to the size you will need but it should be doable.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thanks I'll have a hunt and try a similar looking one
Can't seem to find the same pin layout anywhere think it's safe to say I have no hope of fixing it
Can you post the dimensions of the connector on here. That way we can try and help you with that. I hate for you to have to give up on this. Do you have some "wiggle room " of where that board sits? Can it tolerated slightly different dimensions?
댓글 달기
This company would probably be able to identify and sell the parts you need:
https://www.sweetwater.com/c1193--Drum_R...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank u muchly I'll take a look
댓글 달기
답변을 추가하세요
Cj Allison 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 20
전체 시간: 483
