주요 콘텐츠로 건너뛰기
Drum set accessory to the Wii game, The Beatles Rock Band, which was released in 2009 by Harmonix. This repair guide will give you help on fixing and/or replacing certain parts of the drum set. Identified by model number NWDMS3.
2 질문 전체 보기
Anyone know the name of this part
My drumkit the bandhero model and there's 2 purple audio inputs for the bass drum but mine are broken does anyone know how to find the name to but the replacement part or does anyone know a fix looks like it's got 3 pins
Update (09/21/2022)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
CJ Allison I figure you are looking at the 3.5mm purple connectors. Some places list them as 3.5mm audio jack others strictly as 3.5 mm phone connectors. Not sure where to get the ones that are originally intended for your circuit board but you can replace those with other ones. The main issue is going to be dimensions and location of the contacts. Get some calipers are equivalent and measure the connector. The go check with places like this. There might be some that will come close to the size you will need but it should be doable.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thanks I'll have a hunt and try a similar looking one
Can't seem to find the same pin layout anywhere think it's safe to say I have no hope of fixing it
Can you post the dimensions of the connector on here. That way we can try and help you with that. I hate for you to have to give up on this. Do you have some "wiggle room " of where that board sits? Can it tolerated slightly different dimensions?
댓글 달기
This company would probably be able to identify and sell the parts you need:
https://www.sweetwater.com/c1193--Drum_R...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank u muchly I'll take a look
댓글 달기
귀하의 답변을 추가하세요
Cj Allison 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 112
